The Proteam Metal Magic, recommends to have the FC at 3 or even better at 1 (If sanitizing with chlorine or bromine, these levels should be at or below 3 ppm. Ideal levels should be around 1 ppm), my concern is, during that time, will I not reintroduce algae.
Hi there. Your mileage may vary but I do not drop my FC when I add - for the same reasons you're concerned about. Eg. For me, I've done startup doses with FC at 6 for cya 30. In my case, it worked fine.
I would not add it near Slam level. The reason, or part reason, for the instruction is that high FC breaks down sequestrant faster. However, just like the rest of the industry, the instructions don't really to my mind account for the cya:FC ratio and its buffering effect. Since most mfgs consider a "normal" range up to 3-4 ppm, I suspect that's why they cite this level.
I actually once told Kevin, the proteam tech, that I don't lower my FC and it works fine. But they're not likely to change the recc based on one user who has a FAS/dpd kit at her disposal
Most non TFP pool owners have no clue where their FC efficacy is really at because they have no means to know where their cya is really at. So more specific instructions would be pointless.
In your shoes, I'd actually try to COMPLETELY clear the water of tint if you could stand another few days filtering before you add the sequestrant, because with the clearing you're actually removing the iron itself, which is a rare feat.
Then I might let the FC drift to the bottom of the [fc/cya][/FC/cya] chart for your cya and add, leaving it to work overnight before bring the FC to the upper end of your non-slam chart range.
Don't be alarmed if it clouds the water a bit and takes a few days of filtering to clear. Hope that helps!
Ps - here's an old pic I'd posted last year after I'd added chlorine to my fountain...I think I'd added an ounce or two of metal magic for the second shot
