Hi all! After a disastrous off-season with a pool company last year, we have decided to close the pool ourselves (2nd year owning the home / pool). I feel comfortable after doing some research and watching videos. HOWEVER, the pool company last year said they could not winterize our pump / filter because it sits below the water table. They said that you would have to drain too much water and the safety cover to wouldn't work / would sink in the middle and stretch. So last year every time it got below freezing, I had to go outside and run the pool pump / filter with the safety cover on. Needless to say, if I CAN winterize it, I definitely want to. I know our pump sits below water level because when I clean the pump basket, water continually flows out. Has anyone ever heard of this issue with winterizing? Here are some pictures for reference. Also, my pool is strange in the fact that there is NO main drain shut off valve. The only way to shut off skimmers is to plug them (no actual on/off valve). There are 2 skimmers, 2 returns and one main drain. Thanks!
From last year's closing / as we had a leak
