Hello - New Pool owner here so apologies if I get terminology wrong. I have lived in the house for 1 year now and this is my 2nd closing. All summer no concern about leaks.
I have an 18 year old, inground salt heated concrete pool 22,000 gal with a coverstar auto cover.
I had the pool closed professionally (air blown thru pipes) but noticed there were some leaves at the bottom so service tech said it was fine for me to open the cover later and net the leaves out if I wanted. 8 days later I opened the cover and had noticed water level dropped 3 inches. I am diligent about keeping the water level at the skimmer arrows because I was told it it important for the support of the cover and I had put on a new cover earlier in the summer.
Now I filled the water level back (2+ hours running hose) and after 24 hours I see about 1/2" drop. I called pool manufacturer and they are booked for next month and I called American Leak and they don't service until Spring. The company who did the closing is willing to come back and start the pump (sans skimmer and filter) so that we can start the heater. The current temps are like 40-60F. They are suggesting we run the heater for a few days with pump and get water to a level where the tech can dive in and look for leaks - lead concern is hydrostat valve damage during closing?? Apparently this valve is likely part of the main drain assembly.
I'm buggin out here and worried about a major leak in the winter and not having a safety cover in place -- am I going down the right path? Any other suggestions? Is this just part of pool life or should I be upset about perhaps closing incorrectly? Appreciate any help or advice. Thanks!
