I have an in ground 22,000 gal vinyl pool. I run my pump 24/7 and use the Pool Pal app on my phone.
If you try and maintain a very low chlorine level (3 or less) as is suggested you will have algae problems.
I measure my chlorine every night and add enough 10% chlorine to bring the level to 8ppm. I find that over the next 24 hours the level of chlorine drops between 2 and 4 ppm.
I am adding between 50 and 120 Ounces of chlorine each night. My Cyanuric acid level is very low since I do not use TriChlor Pucks. With this program I do not have to shock the pool
and it stays crystal clear. The Ph does tend to rise and every 2 weeks I add some acid according to pool math.
I test with Taylor K-2006 Kit. Water Temp 85, FC 5-8, PH 7.8, Ta 80, Ch 100, Cya 10
