That's about it. Does your filter have a slide valve or mulitport valve? Just curious.Besides shocking , vacuuming , backwashing and running pump 24/7 , anything else to be done?
It's fine. I see Dave mentioned to not bother with the SLAM just yet, but keeping a higher than normal FC certainly won't hurt. Your water is under a lot of stress right now, so it can use all the help it can get. Be patient. This will be a marathon, not a sprint, so try to take a deep breath and go with the flow.I already dumped a bunch of chlorine in before reading your message , is there a point to test now or will everyone be out of whack due to the super high chlorine ?
Test results at some point would be good, mostly because we're looking at the FC level, but what other parameters are doing after the material has been in teh water for several hours.is there a point to test now or will everyone be out of whack due to the super high chlorine ?
I think so , do you mean could we have turned it to waste and avoided everything going in the pool? Yes , but we aren’t smart lol.That's about it. Does your filter have a slide valve or mulitport valve? Just curious.
Doesn’t seem like there’s much ,there is a bunch of dirt on the stairs that came of a jet there , but the rest seems pretty mixed in at the moment , i fished around the bottom with the net and didn’t get much , just little pieces.Have you taken your leaf net and tried to get any solids off the bottom? I doubt you have any but you want to give that a try,
I will test in the AM and post , test everything?Test results at some point would be good, mostly because we're looking at the FC level, but what other parameters are doing after the material has been in teh water for several hours.
Absolutely.Is it okay to go through my filter ?
Thank you will do. Dry stabilizer pack says to wait 24 hrs to add chlorine afterwards, can I ignore ?I would prepare to go into the SLAM Process. Lower the pH to about 7.2. Then add about 10 ppm of stabilizer to ensure your CYA is at least 30. from there, increase and maintain the FC of "12" as best as you can while doing all the cleaning tasks required. Maintain the SLAM level until you pass all 3 SLAM criteria. You're making good progress.![]()
Yes, ignore. If you are using granular stabilizer, let the sock soak to start making the granules soft and add the chlorine anytime you need to.Dry stabilizer pack says to wait 24 hrs to add chlorine afterwards, can I ignore ?
