Hi,
I installed the hayward cl220 and it’s not filling with water when the pump runs. The filler and pump worked fine after priming again but I can’t figure this out. The dial is set to 3 There arent any water leaks by the hoses that I see either. I’m new to this as well. Do i need to fill the chlorinator with water to start? I can post a photo if it helps. Any help is appreciated.
