Good Morning everyone!
First time user long time reader here, I recently took delivery of a Dimension One Meridian ~375 gallon ozone equipped hot tub without topside aeration controls.
Previous to this hot tub I had a ~300 gallon ozone equipped plug-and-play Roto molded unit that featured Venturi style top side aeration controls and rarely had issues with initial water chemistry. I mention the previous tub as I am having a problem ping-ponging pH and TA as many here experience, I have read pinned posts by the Chemists but my particular problem is as follows (please forgive me if the answer to my problem is in another pinned post).
After consulting my local water report from 2021 my hose end numbers from city water are:
pH:9.20 ± 0.10
Hardness:40 -60 mg/L as CaCO3
Alkalinity:40 -70 mg/L as CaCO3
2021 Water Report
Upon delivery of my new unit I brought the tub up to 102 degrees, brought TA to manufacturer recommended range 100-120 (Waterbear states lower TA in some settings is allowed) and then started on pH however I have used 10+OZ of pH down (sodium bisulfate 93.2%) over the past 36hrs with little pH relief. My Taylor K-1003 kit (the k-2006 kit is on my wedding registry currently) reads up to 8.2+ and i have yet to get reliable consistent readings much below 8.0pH. When following the Acid Demand test and the correlated sodium bisulfate 93.2% recommendations per 100 gallons factored to my ~375gal, the amount added truly is a drop in the bucket with no discernible pH change but TA drops steadily on chemical application. I added notes of air control as I have read numerous posts on this forum from informative members speaking on the byproduct of bubbles in your water and the effect that needs to be taken into consideration, and I have yet to find a way of controlling the addition of air to the water when the jets are running. The overwhelming theme on the pinned posts is that if your pH is high your TA also has to be high as they are related in nature, so my current numbers are as follows:
pH: 8.2+ (had 7.8 lastnight)
TA: 40 - 50ppm
FC: 1 - 3ppm
Temp: 102
Gal: ~375
Ozone Equipped
Filter cycle: 1hr x 4 / 24hrs (I use jets on low speed when adding chemicals, lid closed with chemical addition as outdoor temps are have been -25+)
Sanitizer: sodium dichloro-s-triazinetrione dihydrate 99%
Shock/Oxidizer: MPS 31%
Thank you to those that have made it this far! Does anyone have experience, recommendations or otherwise on how to remedy a consistent pH reading of 8.0+ when the use of pH decreasing products seemingly only effects TA. Is there something that I am overlooking or over thinking? Should I use Sodium Hydrogen Carbonate 100% to bring TA closer into range and then use Sodium Bisulfate 93.2% to drive pH down? Is there a reverse off gassing method? I am currently on the water chemistry merry go round and it sure is something! Thank you again in advance for your help, high pH + low TA is something new to me.
pH:9.20 ± 0.10
2021 Water Report
TA: 40 - 50ppm
FC: 1 - 3ppm
Temp: 102
Gal: ~375
Ozone Equipped
