I just installed an RJ45+ and have been reading about the duty cycle since I noticed it was not generating when I expected to be. My main question is, does the duty cycle count reset after the unit is powered off? In my case at the current colder water temperature, I have the pump and SWG running at 30% for 3 hours (10:30-1:30), followed by a break until it runs another 3 hours (4:00-7:00). As I understand this has a 200 minute duty cycle. So the SWG will run for 60 minutes (30%*200) for each of the 3 hour blocks. Does anyone know if I should see the SWG running at the beginning of the second 3 hour block, or does the duty cycle extend 20 minutes into the next block even though it is powered off for 2.5 hours in between? I tried a few experiments but I may not be understanding this correctly. Thanks
