Having a weird problem that Id like a sanity check on...
Today my old 3/4hp pump came out and was replaced with a Circupool 1.5hp Variable. So before someone asks if something has changed in the system, that answer is yes, however the salt cell and flow switch piping were left intact.
Obviously the new VS pump has more flow than my old 3/4hp pump which is certainly a GOOD thing, however, even at 3450rpm, I am now getting a No Flow light on my generator. I did take the time to pull the flow switch out of the flow path and check to make sure that when the flow switch was made that it was not showing open with my meter.
At this point I am guessing the control box has some sort of fault? Is this just happenstance on the timing? Admittedly, today is probably the first day its been turned on as I have been doing the SLAM and only got to the point of clear water this week and havent needed generation from salt as of yet.
Thoughts?
Thoughts?
