Circupool and Omnihub
Who selected the Omnihub for you? The Omnihub is a basic low end automation panel targeted at the existing pool retrofit market. Hayward says " Hayward OmniHub is the easiest way to add smart control to a pool and spa. " The code words are "add smart controls" which implies a simple existing pool.
The Omnihub does not have any high voltage relays which is what you need to turn on/off equipment like an SJ45.
Any other options @ajw22 ?
Actually, I am going through all of this by myself....... hence all the questions that I make over here. :ROFLMAO: :ROFLMAO:..... I went with omnihub (I think pentair is better), because my equipment (vs pump and filter) are hayward, and I was told that they are not compatible with pentair.........The omnilogic is way too much money for my budget, and I couldn't find anything else.........you don't think that omnihub will work for my equipment??? must I go with aquarite (about $2,000)?????...... all I want is to be able to control everything easily in one place (and maybe online), instead of each machine separately...... and to add a Swg that you guys recomend over the inline clorinator that I got
Filters work with any system.
Your Hayward pump locks you into Hayward automation. Then you need an Aquarite to control the SWG.
An Aquaplus would have done more then the Omnihub + Aquarite.
ok, so I get an Aquaplus I don't need to get 2 items???
The other system to look at is the newer OmniPl
with the omnipl do I need to purchase the aquarite (the swg) as well???
No, Omni PL #HLBPLUS4W comes bundled with a Tcell 940.
The OmniPL has built in networking and app control which I don't believe the Aquaplus does.
