Hello
So I finally have my pool balanced and broken parts replaced. However, my SWG is not producing any chlorine.
FC= 0
PH = 7.4
TA = 100
Calcium = 300
CYA = 80
Salt = 4300 (circupool recommends between 4--=4500)
Labs have been steady for about a week with daily testing. Water is clear but gets a little cloudy when swept. We have been sweeping the bottom and still backwashing post slamming a week ago. The other issue I have is we had Pinch a penny install a new variable speed pump when the old pump broke. After they finished, the timer to the pool stopped working and they are aware of this. the SWG still says it is working and all the lights indicate it is working but no bubbles or calcium buildup as in the past.
I included a picture. The old pool pump cable was wired directly into the box containing the pool timer and they moved the pool pump cable into the breaker box on the right. Not sure why the timer stopped or if this is affecting my SWG even though the light are on.
Thanks for any advice as we know little about electric and if I go back to the pool store I want to know what/if they should be addressing my issue.
FC= 0
PH = 7.4
TA = 100
Calcium = 300
CYA = 80
