I wasn't promoting Leslie's method, I was just concurring what they told be with resources from the manufacturer website since someone said they never said how much chlorine to maintain for fear of lawsuits which just isn't true.
.I am maintaining .5-1.0 with no problems so far
My CYA is 54.
That sounds like a pool store number if so it’s not reliable.
I did confirm that the manufacturer suggests 0.5-1.0 TC levels to be maintained with my Ozonator, however my question is how can one maintain that level with confidence and precision without the TC ever dipping down to 0? When my pool burns through 3PPM+ of chlorine in a day, how can you set it to 1.0PPM in the morning and still have residual chlorine by the time you come home in the afternoon? Never mind the effectiveness of chlorine varies with CYA therefore running stabilizer one definitely needs higher TC values.
The accuracy of that is suspect as other brands that measure the same way have accuracy problems. Hanna makes a FC version you should use that instead if you wish to continue with them
