I'm in Houston and one of the 567,870 people rebuilding my pool equipment after our freezes. Cracked a Jandy valve and the way it's built I needed to replace all of them. I got everything plumbed, rebuilt the top diverter manifold and then added in the Jandy Valves and Check Valve. It was late. And then I woke up this morning and released I used Christy's Red Hot Blue Glue (PVC pipe Cement) - not listed as for CPVC. The valves are fairly close to the pool heater so they will see hot water from hot tube and pool lines. Does the use of PVC glue on lines that will see hot water mean I should cut out and start over?
