- Aug 2, 2016
- 42
- Plaster
- Pentair Intellichlor IC-40
So, I just had the calcium sprayed from my pool. It was a complete drain and refill. The company left a ton of residue and I think even washed a ton down the drain. I cleaned the filters out and alot of it came out. It was so bad there was 3 inches of sludge on the bottom of the filter housing. In any case, less than a week later, my pressure is up close to 10psi higher on low and hits about 30 psi on clean mode. Right after cleaning the filters, it was just over 20psi. The rubber ends of the filters look chewed up too. I think it's time replace after 3+ years and sludge. The questions is.... is it best just to buy the OEM filter or is there a good/better/best when it comes to choosing them? I tried to do research before I asked but can't find anything. These suckers aren't cheap. I'm looking at r173576 @ $133 for one filter. Any advice appreciated.
Thanks
Thanks
