Chlorsync CS30 4 green dashes
Ldawg32
8
Rockville centre
As stated above. My chlorsync cs30 has 4 green dashes on the display. My app says unit is unresponsive. The diagnostic chart says to check the wire going into unit. I checked all the wires and all seems ok. It does not have another option to check. What else could it be?
I am having this same problem. Worked fine for a month came home low flow light was on, reset the power and now 4 rotating dashes for the past day. Did you find a solution? Thank you!!!
I’m having exact same problem, did they brick it with firmware. I’m see a few people saying the same thing.
