Hi,
Started my pool up in mid may. My signature has all the salt pool information. Pool is clear which is good but not getting good FC readings. My Test Kit readings are the following:
FC = 0.5ppm
CC = 1.5ppm
CH = 325ppm
Alkalinity = 170
CYA = 90-100
pH = 7.5
Pool temperature is around 85F.
I've put liquid shock in the pool and afterwards then I get a good reading but then the chlorine dissipates in about 1 hour back to 0.5ppm or so it seems. I was previously using test strips, but switched to the recommended test kit TF-1000 I think it's called.
I also had previously put in phosphate remover which at the pool store told me my reading was around 2000ppm, I tested myself and found it now to be around 300ppm.
Any help would be appreciated.
FC = 0.5ppm
CC = 1.5ppm
CH = 325ppm
Alkalinity = 170
CYA = 90-100
pH = 7.5
