Chlorine problem after AA treatment
After AA Treatment
  • Bring up your pH and alkalinity - use Arm and Hammer Washing Soda first; it will raise both pH and alkalinity.
  • Make sure you test in between because you don't want your pH to exceed 7.2.
  • If your alkalinity is in range, and you still need to raise your pH, use Borax to take it up to no higher than 7.2.
  • You can start to bring up your chlorine. You want to do this slowly. It will take a lot of chlorine - preferably using liquid chlorine only at this time, and try to take it up to your minimum chlorine for your cya according to the Chlorine/CYA Chart.
  • As you slowly raise the chlorine, watch for stains starting to form.
  • If you see stains, ensure the pH is no higher than 7.2, and add more sequestering agent. You should see the stain lift in a couple of hours.
  • Do not raise to SLAM FC levels! Do not do a SLAM for at least 2 weeks!
  • Make sure you keep your pH low (7.2) for a week or two - it won't be hard because the ascorbic acid and sequestering agent will help it stay low.
  • Once your chlorine starts to hold, it means that you have used up the ascorbic acid in the water, and it will be easy to rebalance the pool back to recommended levels.
Check about 30 minutes later to see if it’s still holding. If it is, go up to your level as identified in FC/CYA Levels. If not, only add in small increments until is does hold. You definitely don’t want to overshoot FC into or near SLAM level.
