I have a 28 ft above ground pool that I purchased in 2018 from Watson's and have successfully used the aqua smart system with no trouble since then. Enter 2024 and I could not get my chlorine levels to balance properly so I took a water sample to Watson's and was told I have chlorine lock. I tried for 2 weeks to resolve it by adding blast and then just granular chlorine but nothing seemed to work so I drained 12 in of water out of my pool, approximately 25% of my total water which I had topped off in may. I typically drain 8 to 10 in at the end of the season when I winterize. Now I cannot get the Dang water balanced. Don't know if the problem might be partially because the neighbor was burning yard waste about 10 ft away from my pool on the other side of the fence. At any rate when I called Watson's to find out what I do now with my fresh water they told me to lower the ph as much as possible and then add chlorine. I no longer trust their advice, I need help. I'm a management major and I'm not good with chemistry or engineering. I just want to enjoy my pool and right now I can't even use it. Please help
