707,
Welcome aboard! When reading through the Pat linked you to you'll find that pool maintenance can be pretty easy. We use liquid chlorine or a salt chlorine generator to add free chlorine most of the time. The only other thing you need most of the time is some acid to adjust your pH. We use big box store versions that are identical to the pool store versions and dirt cheap. Other forms of chlorine add something else to your pool so if your pool is already balanced it can easily get out of balance from these since chlorine is consumed and the other component added builds up since it isn't consumed. This creates an unbalanced chemistry in your water that has detrimental impact. It can cause calcium deposits and reduce the effectiveness of your chlorine. There are a few other things to balance but usually they need adjustment way less often like monthly or even quarterly. The underlying chemistry can be a little complex but our methods simplify all this with a simple set of tests you can perform yourself. No chemistry needed. Test results will determine what you need to do to keep your pool very healthy, gorgeous and at a dirt cheap cost. For new members the first thing you need to do is get the kit. "Free" pool store tests are worth what you pay for them. The advice you get from the stores is also very unreliable since they are often poorly trained and conflicted because they sell a lot of expensive potions you don't need. We don't sell anything. We've determined two different brands of tests work well for home owners. You can buy them any place you want to.
Test Kits Compared . Once you get your kit post your results here and we have experts that will help you get started. In a couple days you'll be on auto-pilot. Our experts will always be here to help with any issue you have related to pools. Also, our experts are 100% volunteers. It would help them be more efficient with their time if you could add your signature with key information about your pool type, size, equipment etc. It's very easy,
here's how.
Again, welcome and we look forward to helping you any way we can. You will be joining over 200,000 other TFP'ers use our dirt cheap, easy methods for a trouble free pool.
Chris
