I have been using liquid chlorine since I filled my pool for the first time in February 2014. My water has always looked the same since that first fill and I feel like I have a very good understanding of pool chemistry. However, I’m beginning to think I have had the wrong mindset all along.
I have always targeted the top or above the top of the chlorine range thinking that more was better and it would keep my water clean. This results in water that is usually between 7-10 ppm chlorine. I keep my CYA level at 50 in an attempt to keep the chlorine usage to a minimum in the Texas sun. Maybe I’m using more chlorine than I need and should be targeting the bottom of the range? In pool season, I add my chlorine at night and raise the level to a few points above the max recommended level. This results in a minimum level a few points above the minimum recommended level at the end of the day. It sounds good but I wonder if it’s necessary to keep the minimum that high.
What does everyone else do? Does anyone target the bottom of the recommended range? What happens if your chlorine level drops to 0 or near 0 for a few hours everyday?
