Our pool was using tabs for the last 2 seasons and we started getting small patches of algae with chlorine levels around 5. The CYA was always high (past the 100 reading on our home test kit) so I took it to the pool store- 186!
I drained half the pool and we’ve been slowly filling it to dilute the CYA. Latest reading was 90.
I want to use the BBB method so we stopped the tab feeder (due to the high level of CYA byproduct) and have been sourcing bleach (6 to 7.5%). I used the calculator and added bleach to 4ppm 4 days ago. Swam for 30 min that evening, checked FC the next day and it was 0.5. Added bleach to 4ppm.
Yesterday afternoon I checked and again had 0.5-1 FC. Added bleach, and after a few hours tested again and verified 4ppm with strips and test kit.
This morning I checked to see if FC was close to 4. Checked it this morning and it was 0.5. Verified it was around 1 with our AquaCheck strips. I did swap out cartridge filters yesterday with clean ones but can’t imagine it breaking down that much chlorine.
So I’ve done this a few times and seems like the bleach lasts about 1-2 days then is at close to zero.
Any ideas why this is happening? I’m about to go back to using tabs and dealing with the high CYA and algae! I travel for work so I can’t be home to add bleach every day or two.
