- May 3, 2014
- 62,700
- Fiberglass
- Pentair Intellichlor IC-40
The cya test is not possible to read at that level. The test vial is logarithmic, so round up.
- Test the FC level and add enough chlorine to bring FC up to shock level (see here for correct shock level)
Test and adjust chlorine levels as frequently as practical, but not more than once per hour, and not less than twice a day. Chlorine additions should be frequent, especially at the beginning. Algae and other organic debris will consume chlorine very rapidly at first. As things progress, you will lose less chlorine each cycle and can add chlorine less frequently. - Brush and vacuum the entire pool once a day
- Backwash or clean the filter as needed
- Vacuum up debris as needed
