- Aug 28, 2022
- 7
- Fiberglass
- Pentair Intellichlor IC-30
I am about to install a Crosswind 65-I heat pump.
The manual recommends FC in the range of 2-3 ppm, with a stern warning in bold in that FC MUST NOT EXCEED 5 PPM (see screenshot below):
I use a SWG. TFP recommends I bring my CYA up to 70 or 80, and target an FC range of 5-10 or 6-11. This exceeds the maximum per the installation manual by a considerable margin. Is this a reason for me to keep my CYA lower, along the lines of that for a regular chlorine pool (30-50)? Right now, my CYA is at 40, andI've been hesitant to raise it out of concern for the heat pump. I would also note that I use an opaque automatic cover, which prevents the breakdown of chlorine from the sun to some extent. However, I'm not sure what is behind the recommendation for using so much more CYA in SWG pools?
Separately, the manuals recommended PH is different from the TFP App's "Ideal Range" of 7.6-7.8. Does anyone have insight into this difference, and whether I should go with the TFP or Crosswind Manual's recommendations?
Thanks!
Galen
Thanks!
Galen
