Hi,
My pool is currently not producing enough chlorine even with cover on all the time. Running pump for 8 hours on maximum output with a chlorinator that generates 35g/h. This seems to have happened suddenly as it was fine a month or so back.
Tests Done
Trying to determine if there is any way of working out whether it is the control unit or just the cell. Control unit is about 9 years old and not sure of cell but at least 3 years old but could be much greater than that.
Think I will try add some liquid chlorine just to keep pool going and also test overnight chlorine loss (although does seem more like chlorine generator not working)
Any other suggestions would be greatly appreciated.
Tests Done
- Can see change in mist/bubbles in cell when I adjust the chlorine output on control unit.
- Take water sample - chlorine level close to 0
- Take sample direct from return pipe - gives reading about 1ppm with chlorinator set at maximum (I was sure in the past this read very high and not the low currently showing ie. darker red)
