Mom,
I had assumed that your EasyTouch came with an
internal SWCG power center, but it does not.. So you must have an
external power center. This just means I can't follow the wires..
So, try this... With the system running and with lights on the cell... put the system into the Service mode and see if all the lights on the cell go off. If they do, that means the cell is wired into the pump/filter relay correctly.. If the SWCG has any lights on, when in the Service mode, the cell's power center is not wired into the pump/filter relay.
Not that it matters, but I can't think of any reason that why your electrician did not use the load center in the EasyTouch for all your circuit breakers.. Just Odd...
