Hello,
I may be able to install a SWG so this question may not be necessary, but I thought I would ask anyways.
I was wondering if it is possible to insert a T into the pool plumbing after the heater and install a Chlorinator Check Valve on top of the T where I could manually pump chlorine in through a hose. I know I can automate by using a stenner pump (cost), however location and chlorine storage (Outside, pool shed hot / sun) make this difficult.
Manual pumping will allow the chlorine to mix thoroughly with the water and prevents me from pouring into the skimmer or slowly over the jets and brushing. Cost would minimal.
Besides the T, check valve, and manual pump would I need anything else?? Is this even possible?
