Long time lurker and new pool owner here. 14x28, 12000 gal in ground liner pool installed last year. Swg is a jandy truclear 11k. Everything worked perfect last summer. I removed the swg to winterize. I just installed it back and got the pool up and running. Water is balanced. 7.5ph, 3900 salt. Now this year, for some reason, I can turn the generator on even when the pump isn't running. If my pump shuts off, the swg keeps chlorination which is very dangerous as I can see all that hydrogen gas accumulate. Jandy helpline is zero help. Manual doesn't explain and youtube is no help. Does anything need to be tinkered with on the control panel after reconnecting? I'm in need of some advice. Thanks
