Chemistry questions...
Newdude
6,907
NY
There is no good/better/best. You are either ‘in range’ or not. If your PH is 7.X you are fine. :) At 7.2 and 7.8 be prepared to monitor it a bit more closely to verify it stays there.
Reactions: AveMaria472
mknauss
37,085
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Aeration from people in the pool will make the pH rise. What was the TA? pH in the 7’s is fine.
mknauss
37,085
Laughlin, NV
Fiberglass
Test TA next time you test your water. If you feel pH needs to be raised, add 20 ppm TA worth of baking soda.
