Thanks MartyOnce filled, be sure any water you left in the pool is well mixed with the new water.
Test all parameters with your TF100. Post them up here. Have liquid chlorine, muriatic acid, and cyanuric acid (stabilizer) on hand.
Yes a little algae. Do you think I need to use acid also? In Arizona our water is very hard.
I am gonna add a little more CYA tonight and I bought the FC to a 3 this morning.You need to raise your FC up to the CYA 30 target. See Chlorine / CYA Chart - Trouble Free Pool
If the dot disappears between 30 and 20 you call it 30 as we round up.
