- Jul 3, 2022
- 114
- Plaster
- Hayward Turbo Cell (T-CELL-5)
The pH is a headache to me- I’ve been told it’s because it’s a salt generated pool and they always run higher on pH but as long as I keep the TA even it should be fine…. ? I’ll add some muratic acid tomorrow to try and get it down. Do you think the CYA is okay right now?I would lower the pH just enough to get the CSI to 0.0.
You'll probably add MA once or twice a week. Takes two minutes. Most SWG pools are happy with a pH in the high 7s.The pH is a headache to me
60 is fine for the winter. You'll want ~80 the rest of the year.Do you think the CYA is okay right now?
It doesn't run higher on pH (given all other factors are the same), it does require to add MA to maintain pH.The pH is a headache to me- I’ve been told it’s because it’s a salt generated pool and they always run higher on pH
