I will keep it short for now. Have a pool with raised spa, 8 years old, standard pluming for one pump but no make up for the spa pluming. The builder did not put in check valves to keep the spa from slowly losing water when the system is off. I have replaced the diverters on the jandy valves a few times and that helps for a while. While the diverters do an ok job it would be nice to have no water loss so I am considering installing the check valves myself. Before I remove a fence and dig everything up I would like to be sure that I am placing the check valves in the correct place.
I will attach a simple drawing the just includes pump, filter and pipes to and from the pad for the pool and spa on which I indicate where I think the check valves need to go. Until I remove a fence and dig out some pipes I can't really get pictures that represent it well at all.
I gather ideally I want check valves on both the intake and return sides of the pump:
On the intake side, the check valve needs to be on the pool (drain and skimmer) side of the pump intake diverter
On the return side, the check valve needs to be on spa side of that return diverter.
Of course, they need to be plumbed to flow the correct directions.
I have attached a simple drawing with just the basic components that are a factor (I think) with regard to this problem.
Before I start digging and cutting sections of pipe out I'd like to be sure that my plan is correct. And if I am correct I, then I will have one more question. If I am wrong ... then that question may be a moot point.
Any input would be greatly appreciated.
Thanks
Thanks
