I'm in the process of replacing my heater. My previous heater didn't have a check valve between the heater and in-line puck chlorinator. I only use the pucks when I'm away for a weekend or want to slowly increase CYA (and add chlorine). I always run my pump on a timer, so I understand that the heater will experience high pH when pucks are present and the pump is off. I want to avoid this going forward.
My question has been answered many times, but I keep having difficulty executing an effective search on this site. What check valve do I want? I remember that the metal springs in the Jandy can be affected ny high pH over time. I also remember that the flapper kinds can warp if exposes to high heat from heater (not running pump for long enough after heater shut down).
