- May 3, 2007
- 18,078
- Plaster
- Hayward Aqua Rite (T-15)
I believe most pump manufactures recommend at least 5 to 10 times the pipe diameter but I believe that rule of thumb is a hold over from the water distribution industry where the inlet pipe was fed directly into the impeller inlet. This helped keep a uniform and balanced load in the impeller. A pump with a basket changes the dynamics quite a bit so I really don't think it is as important because the pump basket tends to smooth things out a bit.
