Let me start of by saying, I'm not an expert -- My understanding that the most efficient way to move water with an electric motor is when you utilize the full power of the motor. And by efficient I mean best L/$. That said, if you run a 3.5HP pump, at the flowrate of X L/min when you could use a 1HP pump to move the same X L/min, you would be saving money.
I agree, maybe you have different speeds required for your setup. Maybe you run your pump for $20/mon 24/7 --- Seems crazy, but maybe! Just think, you could run it for $19/mon if you had appropriately sized motors! I digress.
I have no water features, and the pool guys replaced my 2-speed pump with a variable speed/flow pump. B/c I have a Jandy Aqualink, and this guy sells Pentair (and he was wrong when he told me it was compatible), now I have a variable speed pump that has to basically be run as a single speed pump if I want to control it remotely.
Also, please be gentle on me I'm just 'diving' into this after my pool guy really irritated me buy selling me a pump that doesn't work as advertised.
Is there an 8 channel SonOff?
Chris
Is it the 'big relays' that control the 220V pumps? Or from your description, more likely, its the relays built into the control board? (The ones shown in the picture below)My issue is that my relays have failed, and the system I have is so old they don't make replacement relays for it anymore. I will have to get a new control board, that doesn't fit in my current cabinet. It will cost over $2,000 to get the new replacement control board, relays, and cabinet. Seems like a lot of money to me. The tech was nice enough to hardwire my pump so it is on right now.
In essence, yes: you need one relay per thing you want to control. Some of the devices need SPECIAL relays for many reasons. The heater and lights can run directly off the SONOFF relays. The pump definitely needs a separate relay, but you can scavenge it from your current system (as I did).I have been looking at your system and drawings and it seems like you had a very similar problem and I am thinking I will just replace my whole system with your system. It looks like if I want to control more than just the pump I will need to add a relay for each device I want to control, up to 4 for the 4 Sonoff switches (heater, blower, lights, and pump). Since I have to replace the relays should I just get 24VAC relays? If so would I be able to skip any of the DC components?
Yep, I didn't have space in the box to have the full bar for each wire. I'm not super happy with the way it turned out b/c of the relatively exposed ends on the barrier strips where I cut them, but I could add some sort of plastic rubber compound to finish it off.Looks like you just clipped the 6 pcs barrier strips in half to divide your bus bars in half?
I finally got some time to try and set up my Sonoff controller, but I am not able to figure it out. The curveball is that I have 4 breaker switches in my set up 2 - 20 amp breakers for the pool pump and 2 - 20 amp for the lights and other equipment, all coming off another breaker from the main box. I am thinking about just taking the 4 breakers out of the pool control panel so I can duplicate the schematic in this thread. Thoughts?
Fantastic project! Thanks for completing the documentation. I really like that you've demonstrated a way to have remote control at a very low price compared to full-fledged automation costing thousands of $. Not super feature rich but brings the basic on-off and timer control with remote input within reach of many that can't afford thousands of $. Very cool!
Chris
A couple favorites for me would be VS pump using digital inputs for the popular and inexpensive V-Green VS motor add on, and solar heater. Is there a way to use two Sonoffs to get 8 channel control?
I've been toying around with adding VS Pump control... the problem is that would require a little bit of coding and I was trying to avoid that Some people have already implemented the Pentair VSF Pump on this particular controller, so in theory it should be relatively simple.
