I have this filter:Do you have a charcoal filter?
It’s charcoal. Little tiny pieces.What does the stuff feel like? Bits of rubber o-ring maybe? I don’t have your filter, but the only black thing in mine is the o-ring. I think you’ll have to open your filter and look inside.
So...it sounds like there is nothing I can do. Correct?
From the article, not a dig, it's buried in there:So...it sounds like there is nothing I can do. Correct?
Ah! I didn’t realize that was possible. Thank you much for the info!From the article, not a dig, it's buried in there:
"The simple solution to solve this problem is to find another less noble metal to use as a sacrificial anode that corrodes but doesn’t cause staining "
Here's one on Amazon. Link
Do NOT just throw a Zinc ring in your skimmer. It does nothing. It has to be plumbed in and connected to your bond wire.
What media are you using?My filter uses white media.
It’s an ivory colored quartz finish. Just looked blue in the first picture because of shadows.We need to determine if there's copper in the water.
Can you remove the filter cartridges and show a picture of them before you clean them?
Remove the cell and check for scaling, especially blue scale. Look for evidence of the cell plates corroding. Look for metal stains at the exit of the cell.
You can have the water tested for copper.
Do you know of any source of copper, like algaecide or a mineral cartridge or ionizer?
Do you have a picture of the whole pool?
The plaster looks like it has sort of a turquoise color. Is that the original color?
It looks like you had the same issue last year.Charcoal Chunks Coming Out Of Returns?
I've been getting little piles of small black chunks of what appear to be charcoal coming out of my returns. Any idea why this would be happening and how to remedy? Thanks! Ianwww.troublefreepool.com
Does your cartridge filter manual say to use any type of media?
Do you have a full set of test results?
It might be something coming out of the heater, but that's difficult to check.
