Can't get rid of waterline ring
Tym2Fish
65
South Florida
Fiberglass
Hi All,
Fiberglass pool I installed in January. In April, it was screened in. I've got the TF-Pro test kit and water is right on. Just FYI, it's salt.
Now that South Florida is in the rainy season, I've noticed a ring around the waterline of my pool. It's not easy to get off. After lots of scrubbing I tried my fiberglass cleaner for my boat and it works well to remove it. The problem is, every time it rains the ring comes back. It's very prominent where the returns are hitting the side of the pool and the ring goes around about 8 feet or so from where the returns hit the side of the pool so it's coming from the pump apparently, though I doubt it originates there.
I installed a new filter and it's did the same thing the next day. The skimmer is clean and even when we go a week or two without getting in the pool, it still comes back after it rains. Any thoughts would be appreciated.
Is it tacky/sticky at all? As it occurs after rains, something on the screen - pollutants, etc?
That was my first thought but I can't figure out a way to be sure. With the screen being a few months old I could only think it would be something in the manufacturing if that was the actual issue.
Not sticky at all. Won't rub off with sponge and water. Almost like trying to get off old dry erase marker.
I get something like that in my skimmer. I use dilute Simple Green and a scrub sponge.
I suspect it is something from the screen.
I keep 2 tennis balls in each skimmer at all times. They work wonders sucking up oils/sunscreen/etc.
