The higher number is better,, honestly as long as you can manage CSI. I live in an area where CH creeps up, so I started off at about 250... it's at about 275 now... over the lifetime of the fill water in the pool I will average probably the high end of the CH numbers, and really the long term is what matters with that. You don't want to leach out the minerals in the plaster by having it too low, and too high means scaling which means mechanical cleaning at some point. Both will shorten the lifespan. You are okay, especially if you will be creeping up over time.
