Thanks for the comments. I have updated the build thread. THE POOL IS UP!!!jsf0656 said:mark, i cant wait to see the progress you are making with the 24' intex. it inspires every time i watch it!![]()
I do a search for his post, thanks for the reference.jsf0656 said:hayward is one of the best brands out there. should do very well on your pool. the bigger the better is generaly the best advice as far is filter is concerned. look for crookm11's post for advice on plumbing. he has done some very good work on his intex pool and the plumbing!![]()
dmullen said:Hello! I have the 18x52 Ultraframe pool with the saltwater system and pump. I also purchased the Intex 2100 gallon sand filter. How do I connect both of them together since the salt water system has a pump built in to it? Your assistance would be greatly appreciated...thanks! Don
foster400 said:dmullen said:Hello! I have the 18x52 Ultraframe pool with the saltwater system and pump. I also purchased the Intex 2100 gallon sand filter. How do I connect both of them together since the salt water system has a pump built in to it? Your assistance would be greatly appreciated...thanks! Don
did the sand filter come with hoses and plunger valves? When I upgraded to the 2500gph it came with new valves, thats why I ask. If so you could cut the pool liner and add a second intake and return. You could probably find 2 valves and hoses pretty cheap online.
