I have a question on cleaning cartridge filters.
1. I understand you clean the cartridges with the pressure differential is between 8 to 10 psi.
2. I understand the “clean” pressure is different at the three different speeds my pump can run.
3. When I clean my filter and start it up I have recorded this “clean” differential at the three pump speeds.
4. So do you clean the filter when any one of these hits the 8-10 difference? So for example it might hit the 8-10 differential when running at high speed but after that run time back at low it is hit about the differential.
5. Also is there a max clean pressure when you should change out and get new cartridges?
