- May 3, 2014
- 62,674
- Fiberglass
- Pentair Intellichlor IC-40
Nodoes this make sense?
Keep adding the same amount of chlorine each day while waiting on the test kit.
It sounds like you are limping along the best you can until you are armed and can launch a proper attack.Does it sound like I’m going in the right direction?
Do I just adjust ph and cya? And then move onto slamming the pool?
Can I adjust them at the same time?
Report back with #s. It's easy enough to do but it can also wait until after. *important step here with new kit* Read directions carefully and wipe the tip with a damp paper towel in between drops. The test bottle for TA gets static charged in shipping and it messes up the drips for the first several tests.If it is, do I adjust alkalinity
Many people have waited until the weekend when they can be more available. Starting tonight or in the morning wont hurt either. If you need to get a break from the pool you can test/dose earlier than your 2-3 hour time to buy that much time off after. You can hit the pool hard while still getting your weekend errands/activities done.Should I maintain at the 5ppm and then start the slam process tomorrow afternoon and carry thru the weekend?
Thank you again for all the help. I decided to go ahead and added 1.7 gallons of chlorine to the pool as per pool math to get it up to 20ppm. I added it at 9:30 last night.Many people have waited until the weekend when they can be more available. Starting tonight or in the morning wont hurt either. If you need to get a break from the pool you can test/dose earlier than your 2-3 hour time to buy that much time off after. You can hit the pool hard while still getting your weekend errands/activities done.
It's a process. Being patient is the hardest step of the process.was hoping to see a little less green this morning now that I’m starting to get FC readings
You 'should', but if you're testing and adding all the time for SLAM, you'll kill your kit testing a 2nd time for confirmation. So we advise to save supplies and trust that the FC is high enough even if the bottle wasn't full strength. More often than not, it was.Couple of questions, should I be testing after adding chlorine to confirm that FC has really been dosed to the required amount of FC,
So as the process goes, it gets longer between doses as it holds. 2-3 hours is best to start, do the best you can. But 2 hours turns into 4 which turns into 8 and if you hit it hard over the weekend, you'd likely have enough window to get a full workday in on Monday.How long between testing and dosing is ideal?
Thank you again. In my previous experience, eventually the green dropped out and the pool turned cloudy white. Will that likely happen? This is the greenest it’s ever been, and no progress really has been made?It's a process. Being patient is the hardest step of the process.
15 mins with good circulation is all you ever need to mix bleach.
You aren't hurting anything now by going longer between doses, it all helps, but anytime below SLAM level makes the process take longer. Go hard as soon as you get the chance.
You got this.
Again, thank you very much for all help and encouragement. I’ve had this happen a few times in the past couple years, and I’ve always been able to bring it back within a couple days with a couple bags of shock. But this has been the worst I’ve ever had it, and I know I’ve only actually just started the Slam process last night, but it feels like I’ve just been dumping excessive amounts of chlorine with no change at all. Without proper testing and balancing it’s pretty obvious how I ended up here.So it didn't go green overnight and it won't be undone quickly either. Green is alive algae. Milky/cloudy blue is dead or mostly dead algae. The filter has zero to do with killing algae and that's chlorines job. If the pool is still green you have more algae to kill, and the attention should be on keeping the FC at SLAM level. You also absolutely must remove any clumps of muck / leaves / etc or the yucky patches will consume the FC in no time. Testing and adding every 2-3 hours really helps Jumpstart the process at first, but you have to stay at it. It not 'well I did it twice at 2 hours and now I'm taking 15 hours off'. Life gets in the way sometimes. We get that. We all have to manage our days as well. So. Believe me. We totally get it. But anytime the pool is below SLAM it will take longer, no matter how bad of a SLAM it is. Do the best you can and the results will follow.
Got any pics for reference?
Draining is always the easiest path. You may not have a clear drainage path, or water costs may be outrageous, or even a moral issue with exchanging water with the earth (its impossible to 'waste' but sucking thousands of new gallons takes energy and possibly trucking it and isn't perfect either).And finally, if for some reason, as a last resort, do you think a complete or partial water changed would become necessary if for some reason I don’t have any success of this weekend
It depends on the snapshot in time that your sample was taken. You are likely to have more overnight without the sun burning them off. Or if you brush well and stir a bunch up, an immediate test may show an increase but later on not so much.My combined chlorine is consistently at 1 at every test. Shouldn’t it be going up suggesting that the FC is doing its job?
No. FC at normal target level is enough to produce that many CCs. Being a little off on your SLAM target won't matter.I’m going to retest my cya today and confirm that it’s 50ppm for sure. If my first test was off and cya is more then 50ppm, would that cause high FC but low CC?
Use 60 as we always round up.During the test, at 60ppm, I could faintly make out the black dot, it wasn’t till about 50 that I couldn’t see it anymore.
To reduce 60 CYA to 30, it requires a 50% drain. The fill water has 0 CYA so it's an even % or fraction. At 60, 15 CYA is 1/4, 20 is 1/3, 30 is half, etc.I find that cya is higher then originally thought, is there a way to determine how much water would need to be changed out to get to a desired level of cya? If I end up having to change some water out, I’d prefer to get closer to 30-40ppm
SLAM (40% of CYA, 24 FC for 60 CYA) has been optimized between killing efficiency and waste to the sun. No need to tweak it further, it has stood the test of time for thousands of members.Is there a threshold that needs to be met in order for the chlorine to be doing it’s job? Is the 20ppm that threshold?
None whatsoever. Any level on the CYA chart is equal. So you'll be as efficient at a 12FC 30 CYA slam as you will with a 28FC 70CYA slam.Do you think I would have better results changing out a 1/4-1/3 of the water in hopes to drop CYA to around 40-45ppm?
This is what I was thinking. Unfortunately I got called into work today, so I won’t be able to get started till around 3 this afternoon, but I’ll drop my pump in and then pull a siphon on 2 different hoses to drain it down some what quickly. Then the fill process.None whatsoever. Any level on the CYA chart is equal. So you'll be as efficient at a 12FC 30 CYA slam as you will with a 28FC 70CYA slam.
However. It requires far less chlorine to maintain a 12FC. So you are in fact greatly helping yourself, and your wallet by draining. Draining or filling isn't always viable so sometimes it makes more sense to stand and fight. Like with poor exit directions for the water to go, or iron laden well filling.
If you do drain, you only have to fight the (half ?) That's left so right away it got easier. And then it's more economical to maintain the lower FC for slam so you won twice.
