Carousel rotojet
Alexr54
175
Florida
I have a fitting for my spa that broke. It’s called a carousel rotojet.
Searching for it came up with nada. It’s no longer made and available as far as I can find.
Does anyone know what part I can replace it with?
Seems whatever I need to fix on my pool it’s something that is no longer made or super hard to find. I’m a DIYer. I am finding pool equipment manufacturers are not very DIY friendly.
My pool is about 10 years old. I guess that’s how it works. This is my first pool. Have owned it for about 6 years now.
Just replaced the lighting.
1 spa light (which never worked for me). Was a colorlogic 2.5. Replaced with colorlogic 4.0.
1 pool light. Was a colorlogic 2.5. Replaced with colorlogic 4.0.
Over the years it had not been that bad.
Replaced 2 pump motors.
Fixed a small leak around pool light niche.
Fixed a small leak around spa.
Replaced LP pool heater.
Replaced caretaker99 valve motor.
Replaced a bunch of valves for caretaker99
Redid pool equipment plumbing - and redoing more soon.
The rest of the stuff I did are upgrades I decided to do and was not really mandatory.
Like upgrade aqualogic to prologic. Add modules, etc...
It is a HydroAir CAR-311.
I have never personally seen one and all sources list it as out of production. I suspect you will have to replace it with a standard HydroAir jet.
The only source I personally know for out of production parts is a local supplier in St. Louis that has no website and just happens to never throw anything away. I seriously doubt that they have this jet, but I will PM you their name and phone number if you want to call and ask.
