- Mar 5, 2020
- 3,091
- Plaster
- Astral Viron V35
Based on theory, we used to think that both pH and FC where higher in a SWG’s cell but in practice, due to the high flow through the cell, the pH is identical to the pool pH and the FC, at best, is 1-2ppm higher than the pool FC, which is nowhere near SLAM levels. I found this to be true by testing my SWG cell’s effluent. I would assume there still is a higher pH at the cell plate surface but I found no detectable change of pH in the return water.
I know, we are not talking about superchlorination here, but FC and pH are slightly higher in the return water. I did some tests last year, FC was about 3ppm elevated, pH not quite 0.1:
FC in the return water was about 3ppm higher than the pool water.
pH was 0.07 higher in the return water. Was pretty reproducible. I was putting my pH-meter in and out of the eye-ball, and the pH kept jumping back and forth, always the same value. Before I started the the pH-test, I kept the meter for maybe 10 minutes in the water to make sure that the probe had adjusted to the pool water temperature
Together with pH-rise due to increased aeration in the spa, that should show up in stain intensity when metals are in the water. It won't result in sudden massive staining, but it will favour stain build-up over the years in the spa over the pool. I think that's what happened in my pool/spa - but I wasn't around for the first 35 years or so of my pool's life. I only know that my spa was significantly more stained than the pool when we moved in.
But I agree, the main effect in the spa from the SWG would be the FC, pH only to a smaller degree. Aeration due to the bubblers is probably the larger culprit. Especially with TA being higher before I took over the pool.
The localised pH-rise within the cell that we refer to as being responsible for scaling in the cell is really only very localised around the cathode. The bulk water's pH in the cell doesn't change much apart from the small rise that is in line with the increased FC-level.
