- Jul 13, 2015
- 10
- Vinyl
- Intex Krystal Clear
So I am finally going to replace the sand in my intex sand filter after filling in 2013. Didn't use for a year or two so sand has 5-6 season on it and probably could use replacement. I struggle to get pool crystal clear at the beginning of the season and feel new sand could help. I also only net pool in fall so does tend to get some Crud in it. 30x15x4 oval AGP. And I was also only at 2000ppm salt for first 3 weeks running pump so was likely not producing enough chlorine. I added 80lbs salt and should be up above 3000ppm now. Pool is fairly clear at this point just a slight cloudiness to it. Usually it clears up and don't have to do anything. Maybe this your will need to add a little something along with replacing sand to get perfect. I have test kit but never really use it.
Main question and reason for post is how much sand should I add? Namco sells 50lb bags for $12 here in CT so will 100lb be good? IDK if should be 120lb or more so I should get 3 bags or if 100lb is sufficient.
It is a 16in sand filter. Some 16in intex sand filters call for 100lbs some call for 120lbs.
Intex has never had manual for this unit online and not able to get thru when call.
Unit has worked fairly well for me other than having to fix the SWCG electrode plates plastic holder that broke allowing plates to touch:
Pump also seems a bit underpowered as vacuum struggles to create enough suction. That could also be sand issue I assume, or junk lady bug vacuum.
Only other issue I have with it is the tree pollen dongles that fall in the pool suck thru the pool skimmer basket and pump skimmer basket then clog in the screen after pump so I constantly have to remove that part of the pipe and clean them out. Takes 2 minutes but when vacuuming them up can clog up ever two minutes so sort of a PITA.
TIA.
Repair cracked end SWG electrode, plates touching Intex
So I was getting a low salt warning after setting up pool. I just installed new liner. Tested salt and about 3200ppm so thats good. Removed plate and end is cracked at end and plate are touching so going to repair and see if works.
www.troublefreepool.com
TIA.
