Nobody seems to provide CYA where I live these days. I poured in the last 2.8kg I had when opening my pool. The CYA level is already below 30 according to Taylor test as I fill the bottle to the top and the black dot is still somewhat visible. The outside temperature is very hot these days. 41 celcius/106 fahrenheit. My SWG running at 80% half day (morning) cannot keep up. I switched to 60% full day now I end up with 8.5ppm chlorine. The settings are 20,40,60,80,100. Kids seem to feel this high chlorine. The pool is clean so it is not the chloramines. I can play with the timer and probably find a precise duration but the problem seems to be that you cannot set what the equilibrium level of chlorine you have in the pool that easily. You can only seem to find a setting where chlorine will not go up and down, but you don’t know what that level is going to be. So do you first find that setting and then let the chlorine drop to a comfortable level and then bring back to that setting?
