Ah! I had a power surge and my pump/motor went into Safe Mode. I used the method Up arrow, Down arrow, and #1 for 3 seconds and the motor started up. The pump runs continuously now at the lowest programmed speed but I have been unable to set the clock. I assume that I have to stop the pump to reprogram the clock but when I attempt to stop the motor from the external Easy Touch control panel by placing it in service mode nothing happens. Before I attempt anything else I will ask what should I do next to you folks taht are more experienced with these Pent Air VS 342001 machines than I am.
