I am new to TFP and are learning so much! I have been dealing with scale precipitation in the pool. From everything I have read it seems the biggest thing I need to do is get my PH down so that my TA will also come down. I have been adding MA for the last couple of days and it brought the PH down a bit from 8 to 7.6 but it just bounces back, which is due to the high TA, right? Is this a process that is repeated daily until the TA is low enough while lowering the PH? I used the PoolMath calculator and added the amount of MA it said was needed to bring my PH to 7.2 but it only lowered it to 7.6. Am I correct in my understanding that I have to get the TA down to 7-7.2 in order for the TA to come down as well? So do I just continue dosing with the MA until I get the TA down to the desired range?
Question number 2: I want to add borates, but I shouldn't do that until the TA is in the correct range, right?
Saltwater pool, I have ordered a Taylor test kit, but in the meantime, these are results from my local pool store.
My PH is 8
TA 150
CYA 80
FC 8
Calcium 350
We had a pool service for the 1st 3 years of owning this pool and we recently started having all of the white scale flakes in the pool and looked at our SWG and it was filled with scale, we decided then that it was time to learn how to take care of our pool ourselves. I would not have had the courage to do that if it wasn't for this website.
Thank all of you for your help and for sharing you knowledge and experience with us novices!
My PH is 8
TA 150
CYA 80
FC 8
Calcium 350
