Moved from here.
One of them does appear to have two holes, but if there's a valve under it? (in my inground pool), is there a way to close it off?
Thanks!
I found this when searching for a similar issue. I just bought a house with a pool, and the CYA is high so I'm trying to drain/refill. I thought I had shut off the skimmers, and was pumping my water to waste, but then I heard the pump sucking air. Sure enough, after re-filling above the skimmers to verify, my diverter valve switches from one skimmer to the other, but doesn't isolate skimmers from the main drain.Under one of those skimmers there should be a second hole that leads to the main drain.
Beneath the skimmer basket there should be a diverter valve
or
Here's how the spaceship one works.
Thanks!
