Can’t get water balanced. HIGH PH.
dozer11
98
Thompson, ND
I have a 500 gallon hot tub and my PH is high and TA is fine. I lowered PH to 7.5 but that also brought the TA down to 20, so I used baking soda to raise TA but that raised PH again so now I have a PH above 8 and a TA at 60. If I continue to lower PH the TA will go down and I’m caught in this vicious cycle. What do I do?? My FC is only at 3 so that isn’t causing the PH to read high. I’m using the taylor test kit.
Run the pH & TA tests on your fill water. It may be easier to drain & refill than to keep tearing your hair out.
Your sig says 360 gallons but your post says 500, by the way.
Reactions: dozer11
Manage the pH and ignore the TA unless your pH becomes unstable. When pH becomes unstable drain and replace the water. pH is what matters.
