In short, I have an IntelliCenter and have completed the setup wizard, but I am not able to control either of my two pumps in any way with the IntelliCenter.
To give a little more info, I have an IntelliCenter i10PS. I also have two Pentair VSF 011056 pumps (one is the filter pump for the pool and spa, and the other is for the features). The electrician has installed and connected everything to the IntelliCenter, and now I am trying to setup/configure the IntelliCenter to control everything. When I run the setup wizard in the Intellicenter and get to the pump section, it asks me if I want to set up a pump and I say "yes." I then confirm all of the options for the pump (minimum speed, max speed, etc.) and hit next. I then repeat the process for the second pump, and finish the setup wizard and return to the home screen. After that though, I am not able to control the pump at all from either the screen on the IntelliCenter panel, or from the IntelliCenter iPhone app. For example, when I hit the "Pool" button, the pump doesn't turn on. Also, when I use the app and choose "Pumps" from the home screen, it takes me to a screen that shows two selectable options labeled "VSF" and "VSF #2" but there are red boxes next to each of them. In any event, when I click on either "VSF" or "VSF #2" it just takes me to a screen that shows Pump speed: 0; Flow rate: 0; and power usage: 0. It however doesn't give me any options to change the pump speed, to turn on the pump, or control the pump in any way.
What am I missing? When configuring the IntelliCenter do I need to do more than just using the Wizard which apparently just tells the IntelliCenter "hey there are two VSF pumps hooked up to you some where in some way." For example, is there something I need to do to get the IntelliCenter to sense, recognize, and communicate with the pumps that are hooked up to it? Do I need to do more than say "hey IntelliCenter there is a pump hooked up to you," and instead say something like "there is a pump hooked up to you AND it's hooked up to the relay labeled AUX 2"? Is there something else I need to do to get the IntelliCenter to recognize and communicate with the pump so that I can control it?
