Last week I took my water into the pool store for a free test. The CYA was at 201 and I was out of chlorine. After asking what I should do, the pool store directed me toward cal-hypo to avoid adding more CYA to the pool. That didn't make sense to me since calcium was also high. They said there wasn't much we could do as a full drain was really what was needed.
We just re-did our pebble last year so it didn't make sense to me that I was needed to drain my pool again already... Anyway, long story short is I did lots of internet searching and landed here. Read a ton and ordered the TF-100 XL kit.
My pool is clear, though I've struggled with the beginnings of algae showing for the last 10 or so months, especially when the weather gets into triple digits. So about 1x a week, I'd shock and brush and it'd stay clear for another week or so.
Over the weekend, while waiting for my test kit, I decided to try the differential drain technique. According to my math and the run time of the pump, I should have removed about 2/3 of the water from my pool in the time I ran the submersible pump. I then turned the pool filtration system back on, poured in a gallon of 10% chlorine (just so something was in there) and ran the system overnight. The test kit got here today and I tested my water. The CYA doesn't register on the test... I even did the dilution method and multiplying by 2 as described here, and it still is just below the 100 line... so my CYA is showing as 200+ with the TF-100 after draining 2/3 of my pool??
So my question is, is it more likely that my water was way more than the 201 that the pool store registered last week, that my drain technique didn't work right, that I'm doing the test wrong (I did it a dozen times...) or something else?
Full test results:
FC 1
CC .5
PH 7.5
TA 220
CH 500
CY 200+
With temps over 100 during the day, I don't dare completely drain the pool. Advice extremely welcome. Thanks!
Full test results:
FC 1
CC .5
PH 7.5
TA 220
CH 500
CY 200+
